thread top ad
Collapse
Announcement
Collapse
See more
See less
[SOLVED]820-3787 No Image
Collapse
This topic is closed.
X
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • G.Beard
    replied
    Much to my embarrassment, yes it works.
    Thank you for your time.
    Leave a comment:
  • dukefawks
    replied
    So we can call this fixed?
    Leave a comment:
  • G.Beard
    replied
    Originally posted by dukefawks View Post
    Can you do a PRAM reset?
    Oh FFS... I don't even need to say it do I?
    I swear it didn't work before.
    Leave a comment:
  • dukefawks
    replied
    Leave a comment:
  • G.Beard
    replied
    Fresh new screen, no different.
    Tried eternal monitor again, no different.
    Leave a comment:
  • dukefawks
    replied
    SSD controller gets hot, normal. Disconnect everything from the board and test with a known good LCD assembly.
    Leave a comment:
  • G.Beard
    replied
    If backlight work a bad LCD is the first suspect.
    Tried unplugging screen already and connecting to internal monitor.
    If not screen and not connector, maybe mux?... BUT...
    The machine is not actually booting as the keyboard does not light up, there is no sound when entering the wrong password after leaving the machine to boot for 5 minutes.
    Controller on the SSD is uncomfortably hot to touch, can't keep fingers on it. If you wanted to test for a fault on the SSD circuit where would you start?
    At this point I would like to try and rule that out as I think it could be causing blank screen same as as bad SSD can do.
    Leave a comment:
  • dukefawks
    replied
    Leave a comment:
  • G.Beard
    replied
    GPU Vcore at 8.5V seems unlikely, check again.
    heh, yes of course. 0.856V
    Changed it above too
    Leave a comment:
  • dukefawks
    replied
    Leave a comment:
  • arghhh
    replied
    If you have GPUVCORE_EN, then remove L9330 and L9360 and then inject 1v onto PPVCORE_S0_GFX_REG with a power supply and see if it works, if not then fucked.
    Leave a comment:
  • G.Beard
    replied
    Originally posted by arghhh View Post
    What if you remove the SSD? Will it go to missing OS icon after a few minutes?
    I have seen bad SSDs cause blank screen and would not boot from anything while the drive was on the board. I assume then a similar problem on the board could do the same.
    I notice that the external drive LED is not flashing as it does on all good machines I have plugged it into.
    I have be through a laborious process and tested everything around GFX / GPU power and everything reads OK.... Completely at a loss! No fucking idea where to go from here.
    Any guidance please?
    Leave a comment:
  • Sykulski
    replied
    PPVCORE_GPU should be 1V :-(
    Leave a comment:
  • G.Beard
    replied
    Yeah, that was the first thing I tried was to remove SSD, plug external drive (my test drive) and hold alt key for boot options... Nothing.
    PPVCORE_GPU is 0.85V is that right? I don't have a working board to test
    Leave a comment:
  • arghhh
    replied
    Leave a comment:
thread bottom ad
Collapse
Working...
X
