Hi guys, the machine doesn't recognize the battery and partially working with the charger connected - shut down sometimes. I cannot located the TB3T sensor on the schematics and brd file.
Can someone please direct me to its location? Thanks
Tried with a good known battery, with/with out battery indicator connected shows the same error.
Also, PPBUS_G3H seems to me at fault --- PPBUS_G3H=9.9V with battery and charger connected. PPBUS_G3H=8.8V with only charger connected
My bad, the board number is 820-2530. Wrote 820-2850 by mistake.
I used 6258.
The resistance between pins 17/18 and 27/28 of U7000 is the same - 20.7 ohm. Voltage on pin 2 is 16.5V
