hi. yes. both sides L4500 are 5V's. the old cable smelled burned. The hard drive Im using boots to MacOS via USB. Also, and not sure if this is related yet. computer only starts up with battery. Will charge and stay running with magsafe. But will only boot with battery. Thanks for your response. Appreciate it.
You are not using an original 85W charger, but that will not affect the HDD of course.
Beep out the 4 SATA data lines from the HDD connector to C4533,34,35,36. Could be another bad cable or bad connector. Also check if 5V makes it to the HDD connector.
L4500 could be half fried and have resistance, it will drop voltage once it passes some current. Check with HDD connected if the voltage drops or just replace it.
