thread top ad
Collapse
Announcement
Collapse
No announcement yet.
Avoid L2 Computer unless you want junk: 820-2914 216-0810005
Collapse
This is a sticky topic.
X
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Avoid L2 Computer unless you want junk: 820-2914 216-0810005
    So I got some chips from a different supplier as the other place was out of stock.
    Had three boards in today with graphics issues and two of them failed.
    Last week I used chips from the normal supplier on 7 machines and all GPU replacements came out good.
    The failed boards I tried again by replacing GPU once more... Still failing. Could it be some other issue on both of these boards or more likely a bad lot of chips?
    I've attached a picture of the screen after replacing the GPU.
  • #2
    There are no new chips, they are all garbage. Stop wasting time until new stock arrives. My sources say within the next 2 weeks there will be REAL new chips in China, not holding my breath though.
    In your image it can be anything. Bad GPU, bad solder, bad VRAM, damaged PCB, knocked component, you pick. Always heat original GPU to see if issue goes away. Then at least know the VRAM and board were good when you started.
    Removed the VRAM glue?
    Comment
    • #3
      Covered with a few layers of foil tape but I didn't remove it on any of them... working repair or otherwise. I read on AR forum that covering is good enough but then I guess that could be anybody's idea of good enough. I'll start removing it.
      Good advise.
      Heated one of these machine last week and the issue went away.
      The other one I dived right into without checking.
      WRT the machine I didn't check by heating: First GPU gave me split screen effect, second GPU gives grey screen at login screen. I'll just wait until I can buy from the other guys. At least I know what I bought from them so far has been good.
      I'll wait and test when some more chips come in.
      Comment
      • #4
        What date code chips did you get. New 0005/0001 ones have been unavailable since February.
        Comment
        • #5
          The ones that worked are dated 2014. Ones that didn't are 2010/11
          Comment
          • #6
            I have used DC 1617 for 0005 and they worked for me
            Comment
            • #7
              1617 are the only goo ones, but they were sold out weeeeeks ago.
              Comment
              • #8
                date codes are in year/day/month right?
                Comment
                • #9
                  year week.
                  Comment
                  • #10
                    year week.
                    Just got some 1603 I'll see how they go!
                    Chips that are failing are from NYC. Dated 1107 1115 and so on.... All 11xx.
                    Comment
                    • #11
                      1603 ones are fake.....Did you watch the video on this?
                      Comment
                      • #12
                        How do you tell?
                        Video title?
                        Comment
                        • #13
                          https://www.youtube.com/watch?v=cJ8kCGEgOsY
                          Comment
                          • #14
                            Originally posted by Repairable View Post
                            ... You got to be fucking kidding me man. I just opened the rest of the reel and found fucking thermal paste still on one LOL, motherf...
                            These are the ones from NYC.
                            Comment
                            • #15
                              yup duke and louis are always right
                              Comment
                              thread bottom ad
                              Collapse
                              Working...
                              X
