820-2936-B - Turn ON and OFF
menatwork
Green Light - OK
PPBUS_G3H - OK
PP3V42_G3H - OK
PP5V_S5 - OK
PP5V_S0 - 2.20v and drop for 0v (turn on and off fan)
Looks fine? Measure it!
If R7402 is ok then measure voltage on Y2805 should not exceed 1.6V else clock chip is dead.
I assume this was a liquid damage?
larossmann
if resistance over C7050 doesn't exceed 2.2 to 4 ohms then U2800 is probably dead. so check duke's advice because that is the best way to tell if U2800 is dead. i am also going to guess your liquid damage was on the rim, by either vp0r sensor, thunderbolt area, or smc. even if the clock chip has no corrosion or water on it, just water in that area, it means it is dead..
What is is not?? You say no backlight and now there is no image or chime......
Connect a USB mouse and see if it lights up, CPU Vcore present?
Board is working. Connect a known good LCD and hold a flashlight to the back of the Apple logo to check if there is an image.
