hello. i am just working in that board 820-2914
it is not turning on.
pluging in the macsafe the green light is coming short, then off. After 1,5seconds again short green, off.
I removed F7040and 7041. After that I had a flickering green light
the 12.6V are not stable, coming up then down to 0 and so on
I replaced U7000 2 times. On Q7035 pin 4 pulses are nice
on Q7030 its not stable
U7000 Pin 28/29 is 20Ohm
R7010/7011 is ok, R7051/7052 is ok
Q7080 replaced
I have red probe on ground with a good working board on D7005 Pin1/2 infinity, on this death board I have some like 1.080
Now the intresting:
If I hold the front end of the solder iron on pin 1 of L7030 then I have on Pin 2 L7030 12.54V not changing, green light is constant as well. If I take it back(the solder iron) green is flickering and Pin 2 L7030 is changing from 12.6 to 0.
need help please.
Q7080 replaced
Now the intresting:
need help please.
