Have a 820-2530 that had water damage. Ran in ultrasonic cleaner but after it would first turn for a few seonds, turn off then back on. I noticed D6905 had some corrosion which I scrubbed off then it would turn on with the fan at high speed, no image on the screen.
After removing D6905 I noticed pin 1 and 3 pads are missing from the water damage. Do I need to run a jumper wire from D6905 to fix this problem? If so to which part do I run it to?
