I already reballed U8900, it's still the same but i found something out. If i press and hold the power button and then connect the charger, it turns on and it works perfectly. i also can restart the machine.
@2informaticos I will check later and post the values.
as i told you, the machine starts in smc bypass mode. If i connect only charger, without battery, i get the following voltages and if i connect the charger without battery, the fan doesn't spinn:
If i connect an usb mouse, the light of the mouse is blinking.
And the cpu slowly gets hot
Orange light is also present on charger.
And i am using a 60W charger, i hope this is enough.
That board needs 85W charger; be sure to use original one.
If battery has some charge, should also start with 60W charger + battery.
Seems that PM_SLP_S4_L is pulsing; confirmm that.
Check if PM_SLP_S3_L also pulses...
If yes, check if all voltages (secondary supplies) controlled by these signals pulse too.
"Check if PM_SLP_S3_L also pulses...
If yes, check if all voltages (secondary supplies) controlled by these signals pulse too."
An o-scope is able to catch any fast pulse...
