Someone gave me the reading from one 3330.
Diode mode aprox .710 with red probe to ground; 1. inverting probes.
His board doesn't work (liquid spill), but the reading should be good.
on a known working board i can confirm 0.706 is correct diode mode reading on SMC_PECI_L with R5052 removed.
i didn't want to waste time, so i had to use the 3330 board that without ethernet,firewire and sd reader because i had to remove R3943 .
