OSX recognizes battery?
Post PPBUS_G3H voltage with both charger and battery connected.
Next post 3V42 and PPBUS_G3H with battery only.
Both sections of D7005 OK?
Tried another battery? This sounds like a bad battery to me...
Very possible corrosion under battery connector OR that SYS_DETECT_L is off because of a blown R6950. Check that resistor first as well as corrosion near battery FPC. If both ok, likely bad battery.
