I do not see anything in the schematic that refers to 5S power rails. Are you referring to ALL of the power rails in schematic while the board is on like all of the 3.3V 12.6V 5V rails e.t.c
Noticed minor corrosion on the clock chip so replaced and have new results. When board first powers on it only uses 339 miliamps for about 20 seconds before turning off but now it turns back on and at starters using 330 amps again but then stays continuously running between 500-600 miliamps. No image on internal or external still.
Do you still need all of those voltages or could this be a bios issue?
Bios from donar board of had exact symptoms. I think John is right bad CPU at this point. I replaced everything I could find under microscope that looked like it got hit with liquid but still no change.
