820-00244 only one side of USB works
bjf
This computer is fully functional other than the fact that the USB port only works when plugged in one way, but if you flip it over - no power or signal. No change when I try a known-good USB cable/USB. I'm stuck. Any ideas?
bjf
D6900 is good. Couldn't find D6901, 2 or 3. The USB port doesn't work for anything though, meaning it won't detect a drive or any device. It's like the port is not getting power on the one side. The USB power is just nonexistent on that side on my USB power meter.
bjf
Thanks. Turns out there was something very small in the connector that was keeping it from working. I found it once I looked under the microscope.
