C6991 is shorted to ground. I detached the CAP. the short is still there inside the board it seems under the pad... How do I go about to solve that issue? drill a hole in the board through it?
hi 2informaticos, sorry late reply, was busy with my other businesses..
I dig the bottom, there is no continuity now.. But the resistor 10 ohm, still exploded after putting a new one... So strange. what could cause that to happen.. ? The trace is inside the board to the other side.. wont be possible to cut off the trace, unless u have a great idea how to?
I could add jumpers from that cap to the other points its should connect to and see what happens. What do u suggest?
