820-2936 won't turn on(hasgreen light) no liquid damage
bighead
I received this macbook with not turning on issue.
No liquid damage. The board was pretty dusty. But no sing of liquid damage.
When I press the power button the fan spins up a little bit and that's it. It does not do the on-off loop.
Here are the measurements:
PPBUS_G3H 12.57V
PP3V3_S5 3.3V
PP5V_S5 5V
RTC_G3H - 3V
32kHz present
Y25010 oscillates
Looks like when I hit the power button every power rails are coming on except: CPU_VCORE.
Checked U2800 and Y2805. Y2805 does not oscillate. I changed both Y2805 and U2800.
What could this be?
Thank you.
aprendiz
Moderator
Did you check RTC signals to PCH??, R1800 to R1803, should be about 3V on PCH side... Also could be a short on PP5V_S3 line....... Could be C6521, shorted USB port...
bighead
Yes, I checked RTC signals. I forgot to mention it in my first post. No short on PP5V_S3 over 20k ohm.
Edit:
I've also
PP3V3_SUS - 3.3V
PP1V05_SUS - 1.05V
bighead
Definitely no liquid damage. I tried different BIOS, but same thing. I've two same non-working board here for parts. I also tried those BIOS on this board. Nothing changed.
