thread top ad
Collapse
Announcement
Collapse
See more
See less
Where to Order Parts
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • macitech
    replied
    FYI Update
    I changed out the top case but keep the same trackpad cause liquid spill. Ends up Top can was not compatible.DA
    Thanks for your help Duke!!!!!
    Leave a comment:
  • SMMRepair
    replied
    No...those are just date codes. Make sure all pins are still well connected to the pads. Can have continuity and still be causing issues there, but it doesn't look too bad. Make sure to look INTO the connector to make sure no pins are bent down and not making contact with cable, etc.
    Leave a comment:
  • macitech
    replied
    Hi Duke,
    I cleaned the connector w scrubbing bubble and checked the connections. All checkout.
    I had to order a cable from logic board to trackpad from my Apple Authorized Guy using serial number but numbers are as follows.
    Original one 593-1604-B 14.05.19
    New one 593-1604-B 16.11.30
    You think this might be the problem?
    Thanks
    Leave a comment:
  • dukefawks
    replied
    Doesn't look too bad. Good cleaning and a new cable. Then beep through continuity to for all the pins to the trackpad.
    Leave a comment:
  • macitech
    replied
    Leave a comment:
  • macitech
    replied
    Cool Thanks much!
    Leave a comment:
  • dukefawks
    replied
    Toothbrush and some soft scrub will do the job just fine. Don't touch the connector unless you can visually see a burned pin. I think I only replaced it once in my life. Measure voltages on pin 10, 14, 19 too, they are the most common to corrode.
    Leave a comment:
  • macitech
    replied
    Thanks replaced the cable didn't work. I'll have to wait for crest to arrive.
    Thanks
    Leave a comment:
  • dukefawks
    replied
    Nowhere. Either take it from a scrap board or from a dead trackpad, use bottom heat. The connector really being bad is rare! Give it a good clean and replace the flat cable.
    Leave a comment:
  • macitech
    started a topic Where to Order Parts
    Hi
    I have a MacBook Air 1466 EMC 2632 customer spilled beer on it and fried the Trackpad/Keyboard cable connector. Part has much plastic so I assume I can't remove it without melting the plastic.
    Where can I order the logic board trackpad connector from?
    Thanks
thread bottom ad
Collapse
Working...
X
