iambehr
https://www.amazon.com/WEP-858D-Soldering-Station-Suitable/dp/B0055B6NGE/ref=sr_1_1?ie=UTF8&qid=1491516072&sr=8-1&keywords=wep+858d
In my experience this is perfectly adequate for most surface mount work. Used the other cheap stations, Auyoe and the like, and this is the only one that worked.
I have removed ISL chips, keyboard connector, and many LCD connectors for macbook airs and pros.
It gets up to temp and has decent air pressure. I can remove a macbook air 11" or 13" lcd connector in a minute or less.
I have been running two of them for a year now and they just keep going!
Yes, there are better ones out there, but this one is CHEAP! IF you are going to cheap out on hot air this one can get you by.
Thanks,
Stefan
Thanks,
Stefan
