thread top ad
Collapse
Announcement
Collapse
No announcement yet.
Weller WXMP Tips
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • TexpertLLC
    started a topic Weller WXMP Tips
    Weller WXMP Tips
    Can someone inform me on what is the smallest, most precise soldering tip for the Weller WXMP handpiece?
  • TexpertLLC
    commented on 's reply
    When doing U8900 resolder what solder iron/tip is recommended. Does using a chisel tip make the work easier?
  • TexpertLLC
    replied
    Thank you very much
    Leave a comment:
  • Sykulski
    replied
    I use the RT 1 when going small. It is 0.2 mm. But you can get a 0.1 mm. It is called RT 1NW which means it is non-wettable and thereby will not take solder.
    This brochure lists all available tips along with the order number that you can easily use for searching at Mouser or Farnell or other suppliers.
    https://www.soselectronic.cz/a_info/...0_Brochure.pdf
    Leave a comment:
thread bottom ad
Collapse
Working...
X
