820-00928 5v no 20v
Roshon
i have a 820-00928 that had water damage i get no voltage on
pp3v3_g3h 0v
ppbus_g3h 0v 0.5 mili ohms to ground
Roshon
I FOUND THE SHORT ON pp3v3_g3h
at C5165 that's pin 1 pp3v3_g3h
pin 2 GND_SMC_AVSS
I REMOVE IT AND GO 19.5V WITH 3.70A BUT NO BOOT
Check voltage on the big coils.
See what voltages you get on the board.
Test the board alone on the desk; nothing connected, apart of charger.
So the board doesn't power on, is stuck on S5.
Which areas have been affected by liquid spill?
Check diode mode to ground on all big coils; even the SSD coils (smaller than the rest).
