820-00045 charger tripping
Fizzl92
Hello,
this 00045 was water damaged. No obvious signs of liquid. I noticed that U4600 had a small hole in it. I replaced it, fixed a short on 3V3_AON by replacing U4470 and U4650 and changed U4700, U4780 and U7100 but no change so far. My USBC-meter turns on for a second but as soon as it displays "5V" it turns right off again and won't come back on until I unplug the charger from the wall and wait a few seconds to let it discharge internally (my second meters backlight flashes periodically after it also turned on for a short time after I unlplugged the charger from the wall). I suspect a short somewhere on the input circuitry but can't find it. Also, I can't check any voltages anywhere, just resistances, as the port turns off all voltages instantly. CC Lines, 3V3_AON, charger current sensing, PPDCIN_G3H and PPVIN_G3H are not shorted.
If found so many damaged ICs, the board is probably trash.
Did you check diode mode and voltage on 3V3_G3H?
Remove F7140 and check C7143 voltage.
Fizzl92
"Only" U4600, U4470 and U4650 were definitely bad. U4700, U4780 and U7100 were just my next step to try to get the USB communication fixed.
3V3_G3H diode mode is 0.373V, voltage is 0V.
With F7140 removed, C7143 Voltage jumps to ~6,6V (maybe higher as my meter might be to slow...) when the charger is inserted for the first time and turning on, then dropping slowly as the cap discharges.
Fizzl92
I‘m using an original charger and cable. Both work with an identical device with dead CPU (create 20V and charge) and also with other different usb-c devices.
Fizzl92
Sorry. I tested the same internal flex cable together with my charger and usb-c cable on my 2nd „braindead“ board and ist working fine (20V and charging).
Fizzl92
I checked all signals at J4700. File attached for anyone who might need those values from a good board... The differences pointed to U4490. I replaced it and Pin 2 was burned and part of the IC was welded to the pad. I fixed all of that and now its back to @ 5V 0A stable. As I already replaced U4700, U4780 and U7100 what would be the next best step here?
Fizzl92
0V. Q7110 is closed. Current sensing is <6Ohms including my probes. SMC_RESET_L = 0.61V. Diode mode on SMC_RESET_L is 0.56V = identical to my good board. This points to U7100?
Post U7100 basic voltages: P_IN, ACIN, SMC_RST_IN, SMC_RST*, VDDA/P, VR_AON, VR1_3P3, VCC_VR1, LDO_3P0/5P0, AMON, ACOK.
Fizzl92
P_IN =5.2V
ACIN = 1.3V
SMC_RST_IN = 0V
SMC_RST* = 0.6V
VDDP = 5V
VDDA = 5V
VR_AON = 3V
VR1_3P3 = 0V
VCC_VR1 = 5.2V
LDO_3P0 = 3V
LDO_5P0 = 5V
AMON = 0V
ACOK = 0V
