no liquid damage nothing it was updating OSX all of the sudden turned off and does nothing,
yes I get 3.32v on PP3v3R3v0_AON.
I thought that if the led lamp is on means that the board is powered on,
Thanks a lot for your replay. is the pin 1 of C7552 a good spot to inject voltage?
I put the current at max and begin with 0.5 volt. is this the correct way?
You can use any point connected in that power rail; usually the bigger pad you can find.
And yes, the method is correct; start with lower voltage and set amps to max.
In your case, is not a pure short, so even 5V is not too much.
In fact, when the lab power supply indicates overcurrent, then you can lower the voltage and try again.
This is a general rule for current injection...
Dear sir you are right after that I removed it. I see that pin 2 of L7520 still shorted to the ground. I assume that U7400 most gone bad.
Do you know where I can buy this chip? because I couldn't find it on ebay and Alibaba.
No idea if it has firmware; in such case you will need to remove it from the same donor board.
Maybe someone already changed it can tell us if used new...
Thank you for your reply, do you know what could cause this issue? I mean, even if I replace it with a new one without first taking care of the main issue, then it will destroy the new one as well.
U7400 has integrated many output MOSFETs for various buck converters.
If on old boards discrete MOSFETs got burned, do not be surprised if such high integrated chip got burnt too...
One stage fails and you need to change a rare chip, because Apple doesn't allow to repair these power supplies one by one.
