820-00138 - not charging - magsafe green light blink [SOLVED]
nameless
Hey everybody
I've got an issue with 820-00138 motherboard.
It doesn't charge the new battery, had to replace as previous, was inflated.
History : a customer brought the laptop cause wasn't powering on. When opened, the battery was inflated with a lot of dusty mess all around
So I replaced the battery and cleaned all around. After a week a so the happy customer came back saying it wasn't charging( or very slow during night when not used)
So now when plugin different (original) know working magsafe chargers it blinks green. When unplug the battery the magsafe stays steady amber.
The macbook works but unable to charge.
Here some measurements i did (based on similar issue from forum) :
PPBUS_G3H on F7700 - 16.21V - without battery connected
PPBUS_G3H on F7700 - fluctuates 10.81V to 16.1V - with battery connected
SMC_CHGR_BMON - on R5423 - 0.66mV - without battery
SMC_CHGR_BMON - on R5423 - jumping from 0.66mV to 253 mV - with battery
Resistance between pins 27/28 on U7100 - 21.4 omhs
U7001 - pin 5 - 3.42V
U7001 - pin 1,2 - fluctuates from 0 up to 4V when battery and charger connected
U7100 - pin 14 - fluctuates from 0 up to 4V when battery and charger connected
U5000 - R5187 - 2.8V
U7100 was corroded (here some pics) replaced with donor board magsafe still blinking
All measurements were made with original U7100 cleaned and resoldered
Thank you for your help
Regards
  • 2021-10-08 23_07_58-2021-10-08 23_04_41-2021_10_08_23_03_54_ImageView - Paint.png ‎- Photos.jpg
"PPBUS_G3H on F7700 - 16.21V - without battery connected"
Are you sure???
If yes, change Q7130.
Be sure C7125 is good.
nameless
oh sorry 20V with 85W charger and 16.21V with 60W charger
checked Q7130 getting 20V with 85W charger
C7125 wasn't sure if good so replaced from donor
Went from 1.3 mohms to 0.5 mohms
nameless
btw i'm getting fluctuating voltage on pin 1 on U7100 (w/wo chip) from 0 up to 9V (15V on donor board)
nameless
thanks for your reply
I removed the Q7130 and it was shorted indeed ))
I ordered a new part https://www.mouser.fr/ProductDetail/863-NVTFS4C06NWFTAG
Which I received but its too small ))
Here some pics
Do you know where can I get this part ? cause the donor board doesn't have the same and I can't find the same specs
Thank you
Best regards
You can get it from normal laptop boards too (not Apple only).
The high-side MOSFET from any CPU/GPU power supply is more than you need; just pick the correct package.
nameless
lol thanks for your support ))
took it from HP mb and booom
where can i mark as SOLVED !!
