Good afternoon, at first this mac turns on but the image varies sometimes and locks, replaces the u9300 with a new ISL62882c, in tests the mac turns on but without image, can you tell me which pads I can test to identify if this component I bought is defective ?
You can tell me if C9319 has a resistor ? because I ended up bumping into this capacitor and putting a resistor in place, but I put the 1000PF capacitor in this pad.
I resold the U9300 back to display image, but in tests the cooler speeds up a lot and the machine is slow, I installed the HWMonitor, it follows the sensor readings.
I disconnected, but still with the accelerated cooler, which component is responsible for the GPU 2 Die ? when I took the IC I ended up bumping into some components could you tell me if the R9314 its value is 1MΩ in the electrical scheme ? And if it has a resistor right there.
