820-00165-A Fan Spins for sometimes, goes off and spins again. But not turning on.
Saurabh
I installed the same SMC after reball, didn't work. Installed a new SMC didn't work.
Does SMC need any kind of programming?
Should I use one from a donor board?
Of course, always from donor board, same model.
You should have other problem, if original reballed doesn't work.
Which is the actual symptom of your board?
Check all SPI Bus Termination resistors and their traces; with patience, there are 20 approx.
Clean/remove J6100.
PLT_RESET_L goes high?
Then should be a problem with a SMC sensor.
Board just stays on in SMC bypass, or even works?
Check for USB activity at least.
Saurabh
After the bypass, the device doesn't work. Only the USB is active.
SMC sensor switch looks clean. PP3V3_S4SW_SNS is 3.3v and goes up and down with the rest.
What next?
SMC sensor???
It has more than 10 sensors...
"Only the USB is active"
Do you get USB activity, or only power?
Read how to check USB activity:
To be sure, check for external video.
If not present, try known good BIOS.
I still suspect some area affected by corrosion.
Heat CPU (especially PCH area) with quality flux.
Do not apply more than 180-200 degrees, for 15-20s; no need to melt the balls, only burn accumulated crap underneath (if exist).
BTW, I talk about board temperature, hot air station need higher setting.
