Hi all.
I have a water damaged 820-00165-A that has no display, either on the internal panel, or on an external screen.
There is zero change on the screen when power is connected.
I cannot see an Apple logo or folder question mark while shining a light from the back.
I have tried another replacement panel, and on an external monitor, with the panel disconnected.
Tried with two known AC adaptors.
There is no chime.
The fan comes on, the Magsafe light starts green, then turns and stays orange.
I have tested the board out of the chassis, with only the Magsafe2 connector, and ext monitor connected.
The water damage was visible on and around the WLAN card, and on the opposite side of the board.
(For example, close to U7400)
PPBUS_B3H 8.0v
PP3V42 = 3.41v
SMC_LID = 3.42v
SMC_RESET_L = 3.39v
ALLSYS_POWRGD = 3.3v
PPVCC_S0 = 1.05v
PP5V_SO -= 5.1v
If I plug in a USB drive, the light on the USB drive comes on, but stays solid, instead of showing activity.
Suggestions appreciated.
Thank you.
There is no chime.
PPBUS_B3H 8.0v
PP3V42 = 3.41v
SMC_LID = 3.42v
SMC_RESET_L = 3.39v
PPVCC_S0 = 1.05v
PP5V_SO -= 5.1v
Thank you.
