820-00165-A
tipoti
hi,
U5000 was covered in smc flux and it looked really bad. So, I replaced smc. Now, with dc cable on, it has 0.30A & nothing happens. With its battery on, no change, it doesn't turn on, fan turns, greenlight , battery not charging
Did you get SMC from donor board, same model?
Can you post some voltages and signals from power on sequence?
NEW, isn't from donor board???
Disconnect battery, use only original Magsafe 2 charger.
Do you get voltage at L7310/20?
If yes, check PLT_RESET_L.
tipoti
L7630 = 1 Voltage
L7439 = 1.2 Voltage
L7560 = 3.3 Voltage
L7520 = 5 Voltage
L7130= 8.20 Voltage
L3095 = No Voltage
L7701 = No Voltage
tipoti
pin5 = 0.028 Voltage
pin6 =3.4 Voltage
pin7 =0.028 Voltage
pin8=3.4 Voltage
pin4 =GND
pin3=0.028 Voltage
pin2= 3.3 Voltage
pin1= 0.131 voltage
F7140 = 8,20 voltage
tipoti
I removed the Q8150
pin6 =3.4 Voltage
pin7 =0.028 Voltage
pin8=3.4 Voltage
pin4 =GND
pin3=0.028 Voltage
pin2= 3.3 Voltage
pin1= 0.131 voltage
tipoti
1st pin of u1950
pin6 =3.4 Voltage
pin7 =0.028 Voltage
pin8=3.4 Voltage
pin4 =GND
pin3=0.028 Voltage
pin2= 3.3 Voltage
pin1= 0.131 voltage = ALL_SYS_PWRGD
Why do you need to post all these, even repost, if I asked about one signal???
I saw the value in previous post, just wanted to make you avoid wasting time in the future...
Start removing each power good resistor from ALL_SYS_PWRGD, one by one; R8164/65/66/68.
Be sure R8167 is good; does it have 3V at pin 1?
tipoti
before i checked what you wrote i noticed u8080 is too hot
I checked the c8080 and c8081 in diode mode, it gives = 0.008
I removed the c8080 and c8081 and then checked it again no problem but c8080 and c8081 pin 1 diode mode, it gives = 0.008
so i changed U8080 and ALL_SYS_PWRGD gives 3,3 voltage :) ( Q8150 I put it back) but same not turn on it has 0.30A & nothing happens
tipoti
pin5 = 3.4 Voltage
pin6 =3.4 Voltage
pin7 = 3.4 Voltage
pin8= 3.4 Voltage
pin4 =GND
pin3= 3.3 Voltage
pin2= 3.3 Voltage
pin1= 3.3 voltage = ALL_SYS_PWRGD
