got this macbook air as an npo no green/orange light
the machine was in other repair place, they took out the ssd and copied the date, gave machine back as repair not possible.
my client asked me to chek first if this ist the original board from his machine.
so i desoldered the bios chip read it out and the serial was the same. I soldered then the chip back
diagnostic was the smc had no clock signal, i pulled it from the board gave a reballing and soldered back.
the machine was like "brain dead" but already got a fan spin
so i got from another formum vinafxx a clear me bios, flashed the u6100 and solder it back.
now the machine is working very good but camera is not installed problem, als is working, dimms the kb after closing the cam
i tryed from a new display connected to j4200 but still the same
i checked the clock CLK25M_CAM_CLKP for u3900 is there,
i2c lines from j4200 to u3900
MIPI_CLK_P and /N
MIPI_DATA_P and /N
PCIE_CAMERA_R2D_P and /N
PCIE_CLK100M_CAMERA_C_P and /N
PCIE_CAMERA_D2R_C_P and /N
have the same diode mode values like from a working board
I found in the forum that can a problem with the bios, so i found here a clear me bios for my 2017 8G 1.8 machine
2017 - J1WK clean ME - working - 1.8Ghz_8GB.rar
but with this bios still no camera working, tryed with both displays.
L3901 1.2V
L3902 1.38V
is it worth to replace u3900 in this diagnostic state?
MIPI_CLK_P and /N
MIPI_DATA_P and /N
820-00165-A no image
It has problem fan spining and loop after 5 sec and spin again, after clear ME REG, it same , after write bios firmware its power on but no image . cpu_pwrgd is 1.04v . all sys pwrgd also ok 3v what should i check ? Thanks
boards.rossmanngroup.com
L3901 1.2V
L3902 1.38V
