820-00165 liquid damage does not see SSD,
Repairable
820-00165 liquid damage (near SMC) does not see SSD, SSD is checked in differnt mac and works perfect.+
SSD_RESET_L 3.278v
SSD_PWR_EN 0.451v
P3V3SSD_VMON 0.029v should be 0.7v
r3740
r3741
r3742
after replacing r37/40/41/42 i got P3V3SSD_VMON 0.998v
If there was corrosion on R3740/41/42 it make sense that there is something up with U3740 pulling down SSD_PWR_EN.
Repairable
oke, there was no corrosion on those resistors, just replaced them to make sure.
there is no resistor on R1620 it also did not look like there was ever one there....???
i made a wire on R1620 pads and it works 100% perfect atm, after the boot i turned it off again and wil place a resistor on the R1620 pads
but if i do that wil i take a risk of killing the machine ?
aprendiz
Moderator
R1620 is a pull up resistor wich make SSD enable on S0 state, R1696 is a pull up resistor wich makes SSD enable on S3 state, so, R1696 makes SSD enable faster than R1620...
First check if R1696 and traces are ok, also you should use a 100K resistor not a wire....
Repairable
Yes like i stated wire was test iT booted now replaced with r1620 100k from donor
r1696 is good tracés also
thabks for the info about faster defect
