820-00165 No Backlight But Has image
peeka79
Hi, I have a 820-00165 that has No Backlight but you can see the image with a Light flashed from Rear. There was Corrosion under the Backlight Driver Near A5 ball so I Replaced LP8550 and Backlight Fuse but still no Backlight. ANY help will be GREATLY APPRECIATED...Thank You
peeka79
Thanks for your Help 2informaticos...Does the screen need to be plugged in And board powered up to check the voltage on BKL_EN and PMW ?
peeka79
Okay...With screen attached and power to board I’m getting 8.56V on both sides of F7701 but 0.001V at pin 1 and pin 2 of D7701 and L7701... Also I am getting 5V on pin 1 of C7710...
peeka79
Here are more measurements with screen attached and power to board C7704 Pin 1 0.001V
R7715 Pin 1 (BKL_EN) = 0.002V
R7731 pin 2 (BKL_EN) = 0.001V
R7704 Pin 2 BKL_PMW = 2.17V
C7704 Pin 1 BKL_PMW = 2.17V Pin 2 = 2.17V
R7714 Pin1 BKL_ISET = 0.001V
C7711 Pin 1 PP3V3_S0 = 3.30V
I Really Appreciate the Help :-)
peeka79
Thanks Again informatics...With Screen attached and power to the board Q7707 Pin 5 EDP_BKLT_EN shows 3.31V
