820-00165 no power
Kyle93
Arrived with liquid damage mainly in rtc area. Replaced everything but still no power. TP from PPVOUT_S0_PCH_DCPRTC was nearly destroyed. Attempted to jumper from what was left of that to C0805 but no change.
Any other ideas to try or is this a no fix since signal comes from PCH? I do not see anywhere else on the board view to run a jumper to.
"0 resistance to ground"
Do you mean OL?
Unless you checked without removing power from the MLB.
I cannot imagine how do you get 3.3V over 0 ohm resistor...
DCPRTC voltage is only for PCH internal use; 1.5V as normal.
I'm not sure if C0895 is so critical.
Check the 4 PCH's RTC signals.
Kyle93
PPVRTC_G3H 16.15 resistance to ground
RTC_RESET_L 3.3V
PCH_SRTCRST_L 3.3V
PCH_INTVRMEN 3.2V
PCH_INTRUDER_L 3.065v
Kyle93
Some power rails are fluctuating
CPUVR_PGOOD_R only 0.51V
PM_S0_PGOOD flucuates around 0.400-0.450V
0V on PM_SLP_S4_L
what should be checked next?
Kyle93
PM_SLP_S3_BUF_L 0V no pulse
PM_SLP_S3_L 0V no pulse
PM_SLP_S0_L 2.7V with and without SMC_ONOFF_L triggered
PM_SLP_S4_L 0V no pulse
PM_SLP_S5_L 0v no pulse
PM_SLP_SUS_L 3.3V without SMC_ONOFF_L triggered
