820-00165 No SLP Board #2
bjf
I have two identical boards with identical issues and had this thread going: https://www.rossmanngroup.com/boards/forum/board-repair-troubleshooting/2894-820-00165-no-slp
They had the exact same symptoms until the last piece of info that Duke was asking for. I'm not sure of the best way to go about this but rather than hijack my own thread or do all of that over again I'm going to just pick it up from that same spot and post the measurements for the new one.
The issue is no slp_s4 lines. Liquid-damage.
His last entry was: "My suspect of SPI ROM data line is still the best guess. Remove ROM and measure all pins on diode mode." Here is the response for this new board:
1. .590
2. .495
3. .506
4. 0
5. .519
6. .519
7. .511
8 .406
bjf
It's doing everything exactly the same as the other board. All measurements are the same until we get to these for the removed SPI ROM chip. I went through every step from the other thread. Are there other S0 rails you think I should check?
