820-00165
Neil250
No water damage per customer
Amber light on charger
PPBUS_G3H at 1.94V
CPU WARM
Obvious;y no fan spin
U7100:
1: 0V
2: 14.59
3: 3.94
7: 1.17V
8: .326
9: .1
10: 3.43
12: 3.43
13: 3.40
14: 3.40
15: 0.06
16: 1.95
17: 1.95
18: 1.95
19: 5.01
20: 5.0
23: 1.97
24: 2.57
25: 6.52
26: 14.19
27: 14.41
28: 14.41
RES: 27-28: 20 O
RES 17-18: 3.5 O
Q7130
1: 2.57V
8: 4.11V
10: 1.97 and 0.3 ohm to ground
10: .20 V to ground in diode mode
9: no short to ground
so am I short to ground on PPBUS_G3H here?
corrosion on u7400 and u7600
replaced them both with new chips
"10: 1.97 and 0.3 ohm to ground"
Any big coil with the same value to ground?
Apart of L7130, of course...
I'm not sure how do you measure voltage, but 1.97V on 0.3 ohm to ground is IMPOSSIBLE.
Neil250
ok my f up
1.97V
215 O to ground
R7120= .1 OHMS
14 V on Pin 1
WENT BACK TO U7100
PIN 24 2.57 V and 103 OHM to ground
On a working refernce board:
PIN 24 is 10.5 V and 2 MOhm to ground
Neil250
did it
no change
PPBUS_G3H is NOT 0V
It remains 1.96 V
it is being dragged down
CPU IS WARM
My thought:
D7105
Q7180 but I am getting 14V at pin 2 R7120
Post again diode mode to ground at L7130, when F7140 is soldered.
Measure with red probe connected to ground.
That is good value; if measured with red probe at ground.
Post again U7100 voltages; pins 1, 2, 3, 9, 12, 13, 14, 15, 17, 19, 20, 27.
Neil250
OK I will post voltages
I may change the chip
I had used a Chinese chip from Alibaba
I have a US supplier.
Maybe the chip is bad
Neil250
U7100 voltages
Resoldered new chip and inspected solders
They all look good
1:0
2: 14.63
3:3.95
5:.92
6:0
7:1.22
8: .327
9: .1
10: 3.42
11: 3.43
12: 3.43
13: 3.40
14: 3.40
15 : .05
16: 1.97
17: 1.97
18: 1.97
19: 5.05
20: 5.01
21: 4.07V
22:
23: 1.98
24: 2.59
25: 6.55
26:14.18
27: 15.03
28: 15.04
27-28: 20 ohms
17-18: 3.5 ohms
Neil250
done
fuse is good: RESISTANCE is 0.7 ohms
AS A TEST:
removed f7140
0.2V diode to ground pin 1
open on pin 2
THEN OUT BACK F7140
give up on this board?
Changed C1212 as it looked bad and was heating to touch
C1214 VERY WARM but looks OK
Neil250
L7130 voltage back 8.59V (PIN 1&2) with F7140 removed
Short is on the system side
U7100 is outputting PPBUS_G3H
U5450
PIN 3: 2.5 kO
PIN 4&5: 100OHM in diode mode to ground
PIN 6: 19 kO
Diode mode voltage drop to ground on pins 1&2 of L7310 and L7320 is 0 V
Noted Q5510 case cracked open
Replaced
No change
No fan spin
Q5500
PIN 4: 0.07V diode to ground
PIN 4: 185Ohm to ground
replaced, no change
oh well
So you wasted time with good working charger circuit...
Exact diode mode to ground on PPBUS_G3H?
Measure in both ways; red and also black at ground.
Compare values with all big coils.
Neil250
DIODE MODE to ground
RED GROUND=R
BLACK GROUND=B
PPBUS_G3H --- 0.121 0.218
-----------R----B
L7130 0.121 0.218
L7560 0.365 0.390
L7430 0.194 0.370
L7630 0.122 0.218
L7520 0.439 0.678
L3095 0.528 0.627
L7701 0.421 0.587
L7310 0.000 0.000
L7320 0.000 0.000
L7820 0.384 0.727
L3901 0.306 0.532
L7750 0.449 1.206
L2920 0.165 0.503
L3200 0.564 OL
Neil250
swapped Q7630, no change
going to look at U7600 now
could the inductor itself be bad?
also C7630 or R7630 to check
