820-00165
iFix
Hi Guys.
I have this Air it was liquid damage (A LOT) i replaced a bunch of stuff re-soldered everywhere and now i got to a point where i get green light no power. The power button pads have 3v and are triggering but no power. I don't get 3 and 5v on Coils
So, no 3V3_S5 present?
What is the exact PPBUS_G3H voltage?
Check SMC_RESET_L and SMC_PM_G2_EN.
I recommend to reball SMC.
iFix
PP3V3_S5 0.45v
PPBUS_G3H 8.2v
SMC_RESET_L 3.3v
SMC_PM_G2_EN 3.4v
I replaced another SMC still same
Replaced SMC why?
Don't you want to check more things first?
Correct oscillation at Y5110?
Post its DC voltage, if no o-scope available.
Also post U7501 basic voltages; pins 23, 22, 12, 13, 29, 21.
iFix
Y5110
pin 1 - 0v
pin 3 - 1.1v
U7501-
Pin 12 - 3.4v
Pin 13 - 2v
Pin 21 - 3.4v
Pin 22 - 3.3v
pin 23 - 8.2v
Pin 29 - 5v
btw after replacement on U7501 I got 3.3v on on L7560 but 0v on L7520
iFix
J6950
Pins 4 & 5 3.4v and 492 diode mode
PPBUS_G3H is 145 diode mode :confused:
On Q7155 pins 1,2,3,4 i get 8v but on the other side 2v and dropping
Diode mode on PPBUS_G3H looks good, don't be afraid.
And no reason to check battery voltage, if no present.
If SMC was already changed, try known good U7100.
So SMC doesn't control PPBUS_G3H correctly.
You must get 1-1.2V on both pins of Y5110.
Check adjacent traces, resistors and caps; change the crystal.
