mbcontrol
Apple gave the customer the diagnose that the ssd is dead - logicboard must be changed.
I can't find any liquide damage. The board brings the question mark folder.
The hall-sensor on the right side was gone - i put a donor part on it.
R8604 looked like somebody did some work on it. so i recognized that it is an 10k resistor. in the schematic is an 100k resistor shown. so i changed it to 100k.
Here are my measurements. Can you help me to understand which signal is ok? I have not much experience with ssd circuits and i don't understand the low-signals. If a signal is named with an L at the end - must it than be low to be ok?
pp1v2_ssd_hot = 1.231v
pp3v3_s5_ssd = 3.364v
pp3v3_2v7_nand_vcc = 2.685v
pp1v8_ssd_cold = 1.823v
pp2v7_nand_pvcc = 5.137v
pp2v7_nand_vcc = 5.122v
SSD_BOOT_LB_L (Pin4 J9600) = 1.781v
SSD_PWR_EN_L (Pin5 J9600) = 0v
SSD_PWR_EN_LB_L (Pin6 J9600) = 0v
STORAGE_LB_EN (Pin8 J9600) = 3.329v
SSD_RESET_L (Pin11 J9600) = 3.324v
SSD_RESET_LB_L (Pin12 J9600) = 3.324v
SSD_CLKREQ_L (Pin13 J9600) = 3.325v
SSD_PCIE_CLKREQ_LB_L (Pin14 J9600) = 3.326v
P0V9_FIXED_SW (L9300 Pin1) = 0.904v
P0V9_REG_SW0 (L9320 Pin1) = 0.854v
