820-00431-a no power IMac a1418
mogly
good morning sorry but I'm a little beginner on some measurements could you explain to me how I can do the measurement you indicated?
Read this thread first:
Find any test point, or component connected to PM_PWRBTN_L, to check the pulse.
mogly
ok correct me if I'm wrong I connect with a wire j5120 pin 1-pin2,
and then I measure PM_PWRBTN_L on r1885?
mogly
I have tested with your info and i found on datasheet the two pin. I have put just temporar contact and after tested the R1885 voltage 3,45 PM_PWRBTN_L
mogly
When the button is pressed, there is no pulse on the PM_PWRBTN_L
voltage remains constant at 3.5v
When press the power button, PM_SLP_S4_L should go high, from 0V to 3V; not viceversa.
Do you get high PM_SLP_S4_L when the power is applied, before pressing power button?
That's good, means the power on sequence starts when the power is connected.
Do you get S3 voltages too, when PM_SLP_S4_L is high?
Also check PM_SLP_S3_L and S0 voltages.
Page 68 shows you the S0 enables signals.
Just follow each of them and check the corresponding power rails.
First confirm PM_SLP_S3_L presence, of course.
