No-Clean
Clean board overall, had some small corrosion near C3208 and R3203, after cleaning the area and reflowing CD3215 same problem, only 5.2v and 0.02a taken.
I then replaced first the CD3215 that was next to the corrosion and same thing, then replaced the other CD3215 and same thing, those were purchased from Rossmann I sure there are good and both are the C00 ones.
No shorts, but PP1V1_UPC_XA_LDO_BMC and PP1V1_UPC_XB_LDO_BMC are both 0 volts, I connected the charger in all 4 ways, diode mode to ground on those lines are 0.496 and 0.512.
F30000 and F3010 are both fine.
I also checked redriver and looked fine, but removed it to test anyways but same problem, I am still learning about this USB-C boards and I am having a hard time with them.
