820-00840 keyboard ant track pad not working
yair37
no water damage.
U4803/L4800 was blow up. i was replace them and make some jumpers.
pp3v3_s4 - 3.3v
pp3v3_s0 - 3.3v
TPAD_SPI_CS_L 3.3V
PP5V_S4 5V
PP5V_S4_TPAD_CONN -star on 5v and immediately down to 0v and stay there.
Check diode mode to ground there, with trackpad connected.
If no bad value, replace L4800 with tiny wire..
yair37
yes both.
PP3V3_UPC_XA_LOD was shory near U3100, so iwas replace U3100 the short gone but still 5V, then i was replaced also U3200 but the same..
1V1 LDO will appear only on the CD3215 corresponding to powered port.
Did you test correctly?
What about 1V8 and 3V3 LDOs?
We discussed several times about this (small) chip, not present in schematic/boardview.
It is placed on the opposire side of CD3215 chips, near the USB connector.
