820-00840 no brain
iremont
Hey, another board with no brain, board takes 20.17v, 0.150A-0-300A but no power, and if i connect the battery it goes to 2A but no picture internal or external. trackpad clicking and display tested with another working board. where to start?
What DFU, it doesn't have T2 chip...
So you get voltage at L7210/20 with battery alone, but no voltage with charger only?
That is very strange, because there should be no voltage with battery alone, untill press the power button.
With charger alone, which coils get voltage?
There is something strange, please check again L7210/20 voltage:
- with charger alone; not pulsing in first seconds?
- with battery alone; do not press power button.
- with charger and battery, both present.
CPU core voltage should not appear on battery alone, before pressing power button.
So no steady 1.8V at L7210/20 in any case?
Board should start with aprox 1V and drops to 0.6V when boots.
Is there cycling pulse?
Other big coils get steady voltage?
Did you try to start in SMC bypass mode?
iremont
L7210/20 steady 0-0.3v with battery and without
L7310/30 1.8v with battery. 0v without battery
No cycling pulse
smc bypass not working
iremont
i got all schemathics, found 1 problem, near u7100, fixed and got vcore 1.8 with and without battery, but still no image external or internal display
1.8V is to high, and cannot appear on battery alone; until press the power button.
L7310/30 appear on your schematic???
