820-00840 No Wi-Fi + No drive detected
overshoot
I think you were looking the wrong board model. Those parts do not exist on the board.
BTW, it's a 820-00875 however I've checked on the 820-00840 (which is very similar) and those parts number you gave me do not exist either.
Thanks
You're right, I was looking different schematic, probably 00165.
This happens sometime, as I usually have 15-20 pdf schematics open.
Check R2011/12.
overshoot
Both are 100k resistors as expected.
When powered on, the signals are at 3.3V so no reset on both lines.
Regarding the SSD, I have 13V on PPBUS_SSD_FLV.
I also 3.3V on SSD_EN.
I have 3.3V on SSD_SR_EN_L ????
I have 3.3V on PP3V3_SSD_FLT
L8630 is testing fine (4 ohms)
I am getting 1.8V on the PP1V8_S0
Anything else I could test?
overshoot
My reading might be a little bit off with the probes.
I am getting 3 ohms on a known good board for that coil.
overshoot
I believe somebody has it in hands but it looks like nothing was done.
I am just wondering if they could have flashed the Bios with no clean ME region.
Could that be possible that it would be messing up with the drive detection + Wi-Fi on this model?
I can't find any missing components.
And yes I am getting the 3V on both resistors.
overshoot
My bad!... The board is a 820-00875 so Bios did not work.
The board did power up but was brain dead. Fan wentfull speed and nothing else happened.
Any Bios with Clean ME for an 820-00875.
Thanks!
overshoot
Nevermind it's not the Bios. I've tried one and same results.
I will investigate the board more when I have some free time.
