820-00850-a 20v 0.000a 12.67 ppbus
Why do you bother with PPBUS_G3H if even battery is charging?
A problem on battery bus will impede charing battery and also blocks the correct control of PPBUS_G3H voltage.
"Did you try DFU mode?"
after restoring with dfu i'm getting the apple with the progress bar and configurator gives an error. the device stays in "recovery"
I get the apple configurator error as soon as the apple and progress bar shows. do you know where i can the u4770 image?
yes the target machine powers on during the ac2 restore and that error immediately pops up. it powers off when the usb-c data cable is unplugged
i'm not sure what parts was affected by liquid. it was thoroughly cleaned soon after i received it. it stays in this recovery mode and a restore will make it power up but with the error. i'm using a usb type A port on a 2014 mac mini. Maybe that could that be an issue
