Liquid damaged 820-00923 using 820-00293 Schematics and BV. I have all rails present apart from the following :
PPVCC_S0_CPU
PPVCCGT_S0_CPU
PPVCCEDRAM_S0_CPU
PP0V6_S0_DDRVTT
I believe the last 2 won't have any voltages until the top 2 are working.
Both the top 2 come from the U7100
I've check the U7100 and I have:
SDA - 1v
SCLK - 1v
ALL_SYS_PWRGD - 3.3v
CPUVR_PGOOD - 3.3v
both VIN & VCC have the correct voltages.
For shit's and giggles I change the U7100 this didn't make any difference.
Next I've looked at the U7210, U7220, U7410, U7420 & U7430
All of them have 2.5v on the PWM line, 0.00v on the FCCM line and the correct voltages on VCC, VIN, PVCC.
On U7270 (PPVCCSA_S0_CPU) which is working. I get 5.0v on both PWM and FCCM and Vout of 1.02v (schematics says Vout 0.55 - 1.15v)
So maybe with PPVCCSA_S0_CPU working and with all Vin voltage present this rules out the U7100.
Initially as mentioned this was liquid damaged and had a short to ground on the U7210 which was causing PPBUS to short. I changed this and now I have all the power rails.
Not sure what to check next.
PPVCC_S0_CPU
PPVCCGT_S0_CPU
PPVCCEDRAM_S0_CPU
PP0V6_S0_DDRVTT
SDA - 1v
SCLK - 1v
CPUVR_PGOOD - 3.3v
