820-00928 won't charge battery
Kyle93
This arrived with no liquid damage. Issue is when charger is plugged in it will act as though its being plugged in and out every few seconds. PPBUS_G3H voltage with charger and battery 11.15V. 11.50v with battery alone.
12.65v with charger alone but only low battery symbol appears on the screen.
Replaced ISL9239 and C7020 since ohm reading was OL. No changes. R7030/40 appear to be good. Q7065 is not shorted.
What to try next?
Kyle93
R7061/62 reading anywhere from 1.6-2ohm
C7020 21.5 ohm red probe C7020 black probe ground ohm modes
R7060 and traces to U7000 are fine. When the board first boots with battery and charger connected (after both have been disconnected) it appears to be charging fine, however once charger is unplugged and plugged back in the system will then act as if it’s being plugged in and unplugged every other second on all ports.
So you've checked C7020 to ground???
I didn't expect that...
Really strange to get 21 ohm to ground; unless you didn't let sufficient time to discharge remanent power, after disconnect charger and battery.
Kyle93
Yes I will measure again but should be fine since C7020 was replaced along with the isl9239
what should be checked next??
"12.65v with charger alone but only low battery symbol appears on the screen"
S3 and S0 voltages go off after that?
L7211 voltage disappears, or go to1V?
