820-01041-A no 20V
Gurmon
I?ve got an 820-01041-A that is driving me crazy, so I?m here for a 2[SUP]nd[/SUP] opinion. I know these boards are fairly new, so there is not that much info out there.
The problem is I can?t get this board to get 20V from the charger. PP20V_USBC_TA_VBUS remains at 5V.
So, I get the following voltages
PP20V_USBC_TA_VBUS = 5.15V @ 0.06A
= PP3V3_G3H_T = 3.374V
= PP3V3_G3H_RTC_X = 3.383V
= PP1V8_G3S = 0.0V
= PPBUS_G3H = 12.29V
There are no G3S voltages
PMU_CLK32K_PCH = 32.768Khz
I have swapped out all 4 CD32. In case any where faulty.
Still no PP20V!
These are the CD32 Voltages
PP1V8_SLPS2R = 1.802V
PP1V1_UPC_ = 1.11V
PP3V3_UPC = 3.335V
PP5V_S4_X_USBC = 0.0V
There is data on USBC_XA_CC1_CONN. So the charger is talking to CD32.
SMC Reset Circuit
U6940 voltages
PMU_ONOFF_L = 3.38V
PMU_RSLOC_RST_L = 3.38V
CHGR_RST_IN_R = 0.0V
Communication with the SMC
I2C_UPC_SCL = 1.8V
I2C_UPC_SDA = 1.8V
UPC_I2C_INT_L = 0V
There is no activity on these data lines. No pulses at all on my scope.
T2 Voltages
PPVDDCPU_AWAKE =0.825V
PPVDDCPUSRAM_AWAKE =0.802V
PP0V82_SLPDDR = 0.821V
PP1V1_SLPDDR 1.1V
PP0V9_SLPDDR 0.9V
PP1V2_AWAKE = 1.2V
The board is crystal clear. No liquid damage I can see, under the microscope.
Of course, the customer needs some critical data. Since its looking like a SMC and SMC is integrated into U3900 T2 chip its looking hopeless.
Anyone have any ideas on what else I could try or what I could have missed ?
If the "SOC ROM" gets corrupted there will also not be 20V. This is U4770 on 01521 schematic so probably the same on this one.
Problem here is if you flash a good binary in there the 20V will be back but the machine will not power on as the ROM is married to the T2 chip.
So far I do not have enough dumps/machines yet to be able to figure this stuff out. It may be possible to repair the original dump, but I have found that apple has used many different versions of iBoot inside the ROMs. I would need to at least find a known good dump with the same iBoot versions and see if the ROMs can be merged by extracting the unique parts.
So if you want to mess with this you should read the SOC ROM and find a dump from a good board and flash that in and see if 20V comes back. Then comes the at the moment impossible task of fixing the corrupted ROM.
!!1.8V ROM MAKE SURE YOU DO NOT READ THIS ON 3V3!!
Gurmon
Thanks Duke, i'll give this a crack tomorrow. i've got a few of these machines in i can mess about with.
Nice to see your still about.
