820-01521 - A1932 Stuck at 5V
Instafixx
Fuse Diode Readings 0.148
Voltage
F3010 is 20V
F3000 is 0V.
U3100 LDO Diode Mode Readings
PP1v8_UPC_XA_LDOD is .034
PP1V1_UPC_XA_LDO_BMC is 0.526
PP3V3_UPC_XA_LDO is 0.026
PP1v8_UPC_XA_LDOA is .531
"F3000 is 0V"
Did you test connecting charger on its port?
"PP1v8_UPC_XA_LDOD is .034
PP3V3_UPC_XA_LDO is 0.026"
Replace U3100...
Instafixx
Replaced U3100.
Get Voltages at the shorted LDOs now.
Without Battery:
Machine still stuck at 5V.
When plugged into the USBC port corresponding to U3100 - I get PPBUS at 12.3V
When plugged into the USBC port corresponding to U3000 I get pubs at 1.8V
Both Fuse give 5V when plugged into their corresponding ports.
With Battery :
I get intermittent very high fan spin.
Tried DFU Revive but it gets stuck midway without giving any error message.
U3000 LDO is stuck at 2V instead of 3.3V
Is U3000 bad too ?
Instafixx
Replaced both. Now pulling 20V. Fan Spins very high and then goes down. Amp Draw goes upto .543 amps and then goes down to .077.
Instafixx
Wifi Ic was shorted. Removed that. All shorts gone. Device now in recovery mode. Revive was successful and I get Lock icon. But still not on.
Did DFU Revive without Wifi IC present.
Instafixx
L7410/30
L7210
L8102
L8410 (Checked with board on bench)
L8100
All are 0V. No Pulse
Stable Voltage at L7670/90.
