820-01598 5v
Kyle93
Arrived with liquid damage primarily in U6903 area. Replaced U6903 PPBUS_G3H 12.30V Meter is cycling on and off to 5v 0.25
PP3v3_G3H_RTC 3.3v
PP3v3_UPC_XA_LDO 3.3v
PP3v3_UPC_XB_LDO 3.3V
PP1V5_UPC_XB_LDO_CORE 1.5V
PP1V5_UPC_XA_LDO_CORE 1.5V
PP1V8_SLPS2R 1.8V
Checked on another mac and its currently not in DFU mode. No liquid damage anywhere around U3200/U3100
USB-C ampmeter goes on/off, or just current indication varies 0-0.25A?
Check if all AWAKE and SLPS2R voltages are present; the small coils around U7800.
If yes, it should go into DFU.
G3S and SSD voltages come on?
Kyle93
0V G3s and SSD voltages
The mentioned onboard voltages fluctuates at same time with USB-C ampmeter?
Check what happens connecting charged battery.
Kyle93
Yes, onboard voltages fluctuates at same time with USB-C ampmeter.
When a battery is connected, the meter does not come on at all, if it does its only for 1-2 seconds. Meter is on around 10 seconds without battery.
There must be something more affected by corrosion.
You can't enter DFU mode if USB-C voltage cycles on/off.
What voltages do you get connecting a charged battery?
Kyle93
I do not have a spare charged battery for this model. Any other suggestions or just order a battery for this repair?
