820-01598 No power, PP1V8_SLPS2R low
This board was liquid damaged but not very badly. Some corrosion around U6903 and PP3V3_G3H_RTC was shorted to ground. I removed U6903 but it was still shorted so I injected voltage and found U7800 was getting hot. I removed U7800 and the short was gone. I replaced both U6903 and U7800 from the same model donor board, and I now get 3.3v on PP3V3_G3H and 12.3v on PPBUS but only about .450v on PP1V8_SLPS2R. I have 0v on the other coils around U7800 also. I assumed the U7800 I got from the donor was bad so I removed it, reballed it, and put it back on the donor board, just to see if I would get 1.8v on PP1V8 and I do get that voltage on the donor, so I don't think this U7800 chip is bad. I have reballed it again and re-soldered it to this board and now back to about .350v-.450v on PP1V8 so something on this board appears to be pulling it down. I do get 20v on this board so idk if that rules out an issue with the CD3217's and T2 or not. Any idea what to check?
Did you compare diode mode reading on 1V8_SLPS2R betwwen the two boards?
Do you get other SLPS2R and AWAKE voltages?
Check LDO rails of U7800.
I get .362 in diode mode on that rail on this board, which seems normal and does match a good board. I do not seem to get any other voltages from the PMU.
PP3V3_G3H_RTC - 3.3v
PP3V3_G3H_PMU_VDDMAIN - 0v
PP1V8_SLPS2R - 0.375v
PP1V1_SLPS2R - 0v
PP0V8_SLPS2R - 0v
PP1V2_AWAKE - 0v
PP3V3_AWAKE - 0v
PP1V8_AWAKE - 0v
LDO_CORE - 0v
PMU_LDO3_OUT_R - 0v
LDO_RTC - 0v
PP3V3_S5 - 0v
I did not find any shorts on the LDO rails but I found that LDO_CORE was OL when I was checking, which seems to indicate it was not connected to U7800. I removed U7800 again and checked continuity and it looks like the trace is broken. I found a few broken traces to U7800 so I don't think board is fixable unfortunately. Thanks anyway
