mbcontrol
I need help with a 820-01700-A. It came with liquid damage and one completely dead usb-c port. Three usb-c ports was working with 20v and booting into the login mask. I fixed the liquid damage areas on the board. The most liquid damage was around UB300, UB400, UB700, QB701, LB700, R8601, C9081 and U5800.
After changing the UB400 (CD3217B12) for the dead usb-c port, all four ports are stacking now at 5v and ca. 297mA.
Because UB300 was also liquid damaged, i changed it renewed it also - so UB300 and UB400 are new.
I bought the "new" CD3217B12 chips from CN/Ali. They look like really new - not reballed. I hope they didn't sell me fake-chips. I Didn't see chips like this before - normaly they look reballed and used.
Here are my measurements (sorry for the long list):
PPBUS_G3H = 12,29V
PPBUS_HS_GPU = 12,29V
PPBUS_HS_OTH5V = 12,29V
PPBUS_HS_3V3G3H_T = 12,29V
PPBUS_HS_3V3G3HRTC_X = 12,29V
PP5V_G3S = 12,29V
PP3V3_G3H_RTC_X = 3,36V
PP1V8_SLPS2R = 1,80V
TBT_WAKE_L = 1,79V
TBT_WAKE_3V3_L = 3,31V
PPDCIN_G3H = 5,10V
PPDCIN_XA_G3H_F = 5,10V
PPDCIN_XB_G3H_F = 5,10V
PCH_RTC_RESET_L = 3,00V
PP3V3_G3H_T = 3,30V
PMU_ONOFF_L = 3,30V
PPVBUS_USBC_XB = 5,11V
PPVBUS_USBC_XA = 5,11V
PP3V3_UPC_TA_LDO = 3,35V
PP3V3_UPC_TB_LDO = 3,35V
PP3V3_UPC_XA_LDO = 3,38V
PP3V3_UPC_XB_LDO = 3,38V
PP1V5_UPC_XA_LDO_CORE = 1,58V
PP1V5_UPC_XB_LDO_CORE = 1,58V
PP1V5_UPC_TA_LDO_CORE = 1,58V
PP1V5_UPC_TB_LDO_CORE = 1,59V
Here comes the rails without voltage:
PPVCC_S0_CPU = 0V / 2,92Ohm
PP1V8_G3S = 0V / ca. 205Ohm
PP1V8_S5 = 0V
L9520 Pin2 (PP0V9_SSD0) = 0V (Diod = 0,34V
L9530 Pin2 (PP1V8_SSD0) = 0V (Diod = 0,35V
L9020 Pin2 (PP0V9_SSD1) = 0V (Diod = 0,14V, after a while second measurement 0,43V)
L9030 Pin2 (PP1V8_SSD1) = 0V (Diod = 0,25V, after a while second measurement 0,40V)
L9080 Pin2 (PP2V5_NAND_SSD1) = 0V (Diod = 0,08V, after a while second measurement 0,41V)
Enter in DFU-Mode is possible.
PPBUS_G3H = 12,29V
PP5V_G3S = 12,29V
TBT_WAKE_L = 1,79V
PPDCIN_G3H = 5,10V
PP3V3_G3H_T = 3,30V
PMU_ONOFF_L = 3,30V
PP1V8_S5 = 0V
