820-01700 not booting
Kyle93
This arrived with no liquid damage but seems to be brain dead. Fans spin but no chime or caps lock light. Screen remains black with no image.
Tried a a DFU restore since data is not needed which completed successfully but no change.
What should be checked next?
Kyle93
LA950 0.753V
LA870 1.353V
LA860 1.353V
LA850 0.872V
LA750 0.715v
L7231 0V
L7330 1.053V
L7221 0.253V
L7330 1.053V
L7221 0.253V
L7211 0V
L7420 0V
L7410 0V
L7211/21/31 are tied together (CPU core) and correct voltage should be aprox 0.7V, after 10-15s (when board boots).
It should drop from initial 1.1V aprox.
Kyle93
L7211 stays at 0v when the board is powered on. No voltage from when the board is first powered on or even after a couple minutes
Kyle93
I checked again and for a few seconds at times a small amount of voltage will appear but it never goes up to 0.7V
Kyle93
PP1V8_S5 is 0v
diode is 0.285 but on a good working board diode is 0.345
Should voltage be injected to find the partial short?
I doubt you can find something injecting voltage.
Too high resistance to heat anything with 2V even.
Possibly bad U7800.
It should be able to deliver 1.8V, as there is no pure short.
Kyle93
PM_SLP_S3_L also had a partial short so replaced U1200 now have 1.8V PP1V8_S5 along with 3.3v on PM_SLP_S3_L but no changes.
Performed another DFU restore.
L7221 is a steady 0v from when board is powered on
Possibly bad CPU too.
PCH, CPU and BIOS are involved in CPU core generation.
Once DFU has been performed (without errors), T2 has rebuilt its internal BIOS; new PCH requires that.
Did you test the board alone on the desk?
Check U7100's power and enable.
Inspect its area for damaged components.
