820-01700 stop working
bartech
There was a short on c6961 i change and now i got on all usb c 5.18-5.22v dont get 20v
ppbus_hsoth5v - 12,31v
pp3v3_g3h_t - 0
ppbus_hs_gpu-12,31v
around u7650
only voltage on
c7659 - 12,3v
c7653-3,3v
Did you check the 4 resistors above mentioned?
If all good, replace U6960.
Just in case, check first if R6900 really has 0 ohm...
bartech
u6960
1-12,44v
2-0.81v
4-0.81v
12-0v
8-1,5v going down slowly
14-1,10 going slowly down
16-5,16v
20-5,37v
24-0,84v
r6900 - 0
You can measure R6970/6 onboard.
R6971/2 can be properly checked only disconnected from the circuit.
You should solder one pin on some pad on the board, leaving the other pin "on air".
Is the safest way to check them in ohm scale; completely removed from the board, you can easy loss them.
Also check their traces.
Just in case, replace C6998.
bartech
i change r6971/2 ang now on termal u3900 , u7800 and u6960 get hot on usb c volts goin up and down 5,22-4.9 v
when there was short on c6961 it was similar
l6960 wolts ar jumping from small amounth to 3,14v
