820-02016 - 5V / 0.02-4 A - No boot
I have an A2337 (820-02016) with 5V and 0.02-4 A on both USB-C ports.
- PPBUS_AON = 11.80-12.25V
- PP3v8_AON_VDDMAIN = 3.8V
- PP5v_S2 = Missing
- PP3v3_S2_UPC = Missing
- PP1v25_S2 = Missing
- PP1V8_S2 = Missing
- PP3v3_UPC0_LDO = 3.3V
- PP1v5_UPC0_LDO_CORE = 1.5V
- PP3v3_UPC1_LDO = 3.3V
- PP1v5_UPC1_LDO_CORE = 1.5V
- PPDCIN_AON_CHGR_R (without battery) = 4.1-5.1V
I noticed when the MacBook is fully assembled a clicking noise at the CPU/Audio board area.
Is the firmware bad? (When I turn on the MacBook - fully assemebled - it doesnt go into recovery/DFU automatically) - So I assume the firmware is good?
Edit: Not possible to get it into DFU mode.
Board looks clean and the previous owner told me he that he close the MacBook and on the next day it stopped working. (no boot)
- PP5v_S2 = 0.287
- PP3v3_S2_UPC = 0.447
- PP1v25_S2 = 0.268
- PP1V8_S2 = 0.330
I have checked the following:
- PP1V4_LDO_PREREG = Missing / 0.291
- PP1V5_VLDOINT_MPMU = 1.45V
- PP1V8_AON_MPMU = 1.8V
- PPVDD_PMU_LDO_PREREG = Missing / 0.291
- USBC0_3V3LDO_EN = 0.525
- USBC1_3V3LDO_EN = 0.527
- P5VS2_EN = Missing / 0.368
"P5VS2_EN is produced by the PMU, U8100.
A missing enable signal can mean U8100 is bad, or there is a communication issue with U8100 and the SOC/other components. A firmware issue can also * *likely* cause missing enable signals from PMICs on the M1 machines. As of 1/14/2022, this remains rare."
Source: https://repair.wiki/index.php?title=A2337_2020_MacBook_Air&mobileaction=toggle_view_desktop
So maybe the firmware is bad? Because the diode reading of the enable signal is good.
I expected output voltages.
Try again on page 34; U8100 (SYM 3 OF 6).
There are 3 LDOs to check, all other NC; also check VREF_ADC.
You've posted only one!
- MPMU_VREF_ADC = Missing / 0.559
Which LDOs are missing? I can't find any LDOs (without NC) - could you please help me out. (im on page 34)
- PP1V2_S2 = Missing / 0.336
- PP3V3_S2_UPC = Missing / 0.447
Clicking noise is coming from "Q5800" - When I connect the battery and USB-C cable (for charging) the values are 5V / 0.36A - Q5800 is getting hot.
I have already replaced it - no short on PPBUS_AON after doing the same (battery charging cable etc.) the short on PPBUS_AON is back again (only when battery is connected) - Any idea? Clicking noise is also back again .... even with a new Q5800.
Checking diode mode with power applied (battery connected)???
How could you have short if PPBUS_AON and 3V8_AON are generated?
U8100 is suspect, if doesn't generate all necessary LDOs.
Ok not the battery is causing the "short" - only happends when the audio board is connected.
PPBUS_AON (with audio board connected) = 8.1V / Diode mode says "OL" (measured while turned off - not connected to charger/battery)
PPBUS_AON (without audio board connected) = 12.26V
I think I will order a new PMU IC (U8100 / 343S00438).
Edit: I have removed the short from the audio board - PPBUS_AON is now on 12.26V with audio board connected. (Clicking noise is gone)
PPBUS_AON is the mother of all voltages from MLB; apart of CD3217 LDOs.
Did you test the board alone on the desk?
You had PPBUS_AON before.
Something happened when you've cgahnged U8100; maybe heat affected other components.
Post U5200 basic voltages; P_IN, AUX_DET, SMC_RST_IN, VDD/P, A/BMON.
Yes I have tested it without anything connected. (no audio board etc.)
PPDCIN_AON_CHGR_R = 5.0-5.1V
CHGR_AUX_DET = 1.2V
CHGR_RST_IN = missing / 0.580
PPCHGR_VDDA = 5.0-5.1V
PPCHGR_VDDP = 5.0-5.1V
CHGR_AMON = missing / 0.591
CHGR_BMON = missin / 0.592
A/BMON look too high, if PPBUS_AON is not present.
Check resistance over C5220/60.
Remove F5200 and check C5254 voltage.
"CHGR_RST_IN = missing"
Why do you think that?
Looks good for me; if really no voltage there...
