820-02098 A 5v unstable amperage
Djsp
I have this card which, if powered by JG600, restarts continuously and 0 to 5v with unstable amperage, however if it is powered by JF600/1 5v 0.37 and then 0.02 stable PPBUS_AON 1.5 and nothing PP3V8_AON
Keep fuses removed and post U5200 basic voltages: P_IN, AUX_DET, SMC_RST_IN, VDDA/P, EN_MVR, AUX_OK, A/BMON.
Also check resistance (ohm scale) over C5220/60.
BTW, write directly into bottom reply box, instead of clicking Reply button.
I don't see any reason to quote an entire post visible few centimeters above...
Djsp
P-IN: 0.563
AUX-DET: 0.570
SMC-RST-IN: 0.565
VDDA/9: 0.467 / 0.465
EN-MVR: 0.606
AUX-OK: 0.641
A/BMON: 0.645
C5220: 68K
C560:3364M
Still missing PPDCIN_AON with Magsafe 3 connected?
Check FF200/1 & FG200 integrity.
Also check diode mode to ground at PPDCIN_AON.
Do you get correct LDOs from all CD3217 chips?
Djsp
on C5250 I have 12.25
I measured the LDOs of UF400 UF500 UG400 with respective USBCs connected and I get LDO. I don't have the same card to compare the readings but based on openboarddata PP3V8_AON it's 0.300 instead I measure 0.157
Mmm, I think you've posted U5200 diode mode readings, instead of voltages; why???
"post U5200 basic voltages"
So you get C5250 voltage only when the fuses are removed?
Djsp
I repeat the readings but with the fuses in their place if usbc connected to UG400 I have the attempt to start all the voltages are unstable and ppbus does not go beyond 12.30 and restarts continuously at 5v while on the other usbc I get 0.02 A and ppbus drops to 1.5, sorry if I misunderstood I redo the voltage readings
Djsp
exactly but when I connect magsafe to the usbc corresponding to JG600 it restarts continuously and rises up to 12.25, while with the magsafe connected to the usbc corresponding to UF400 and UF500 instead it lowers up to 1.5v
Djsp
Unfortunately I don't have a similar model, I have another working card but blocked on the way to make comparisons, However I suspect it could be the spi rom of the usb c ports
Djsp
then the usbc port related to ug400 restarts continuously, in diode mode on 3v8_aon I have 0.060 this after removing cg010
